AC problem
Old Jul 27, 2010 | 11:16 AM
Joe's Avatar
Joe
Default AC problem
After trying everything we figured out the high pressure switch would work some times , replaced it and everything is working fine !
BUT !
The electronic dash control will only go down to 75 and if I bump it up to say 80 it won't come back down unless I pull the fuse and it will reset itself at 75 , I think I need a new or replacment dash control and have been told it must come out of or be for a convertable , coups are different ! could the problem be something else ?
Old Jul 27, 2010 | 11:27 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
It should go down to 65 degrees. Do you have your FSM? It details how to pull climate control trouble codes and will help you correctly diagnose the problem.
