Corsa Outer Tips Functioning Video Proof.
Old Jul 29, 2010 | 10:39 AM
GKK's Avatar
GKK
Originally Posted by ElvisGraceBo
I wish we could get somone from Corsa to settle this thread....
From Corsa's Website:
CORSA's Patented RSC™ Technology allows us to acoustically style the sound of your Corvette to give you the true voice of performance without the annoying drone while cruising.
No Drone - This is what sets us apart from other exhaust manufacturers: RSC™ technology eliminates "problem" frequencies that cause interior drone/resonance at cruising speeds. You can add CORSA and enjoy your car at idle, on acceleration and while cruising down the road.
Old Jul 29, 2010 | 07:44 PM
Aurora40's Avatar
Aurora40
Originally Posted by GKK
Outer tips = Exhaust flow too control Resonance
What are you basing that on? From past conversations with Corsa, my impression was this:
Like most Corsa's, there is only one pipe and one resonance chamber in a muffler. On systems with dual tips, they generally "Y" out to two tips. On the C4, there is no room to do that because the tips have to be so short. So one tip flows and one does not.
Apparently to address the appearance concerns, they added that little stub of pipe to get some flow into the case (the second tip and the case itself is mainly for appearance and so the muffler hangs properly). I suspect they blocked the tip off mostly so that only a little exhaust flow went in there (as it is bypassing the resonance chamber). This has not addressed the appearance concern, though, as the outer tip still stays much cleaner than the inner.
If you plug the outside tip, do you get a lot of resonance? Why do you say it's for resonance control?
Old Jul 29, 2010 | 08:12 PM
GKK's Avatar
GKK
I should've wrote, "Outer tip" = Auxillary Exhaust Flow.
I'll edit the post.
The Primary exhaust pipe in the muffler case with the multiple cylindrical tubes around it, is how the sound is cancelled out and Resonance eliminated.
I'm just guessing that the smaller exhaust pipe inside the case has something to do with controlling the sound also, as part of the complete package.
Old Jul 29, 2010 | 11:56 PM
88BlackZ-51's Avatar
88BlackZ-51
I dont mean to sound like a smartass, but why are we talking about this?
Every Corsa system on a C4 I see looks very similar to this
It doesnt take rocket science to figure out what is working, and what isnt. The tips lool like crap imo.
Old Jul 30, 2010 | 12:17 AM
GKK's Avatar
GKK
That's the whole point of this thread. Even though the Outer tip doesn't get as black as the Inner tip, it still does have exhaust coming out of it.
It doesn't flow enough for any performance gain but, that's not what this thread is about. I'm just showing that it's not a dummy tip.
Old Jul 30, 2010 | 12:19 AM
88BlackZ-51
Ok gotcha.
Old Jul 30, 2010 | 11:04 AM
thedudeman321's Avatar
thedudeman321
I'd like to see this done with the results that follow..
Old Jul 30, 2010 | 01:52 PM
kenmohr's Avatar
kenmohr
I can tell you from experience that corsa exhaust is quieter inside than my stock was and give me a feelable difference in HP.
Go to corsaperf.com read their claim. It's true.
Old Jul 30, 2010 | 02:00 PM
uptown193's Avatar
uptown193
I have these mufflers and I really like the sound they give while cruising and on hard acceleration. They are still considered dual exhaust because they extract exhaust from each side. The outer pipe only lets out very little about of exhaust, I can feel it when i put my hand there. When on highway there is no resonance/drone. I recommend them.
Old Jul 30, 2010 | 02:01 PM
ElvisGraceBo's Avatar
ElvisGraceBo
In Corsa's words, this doesn' t say anything about the outer tips flowing anything. Also, there is NO residu from exhaust in the outer outlet. Let's get Corsa to say either there is flow thru both out lets or there is flow thru only one outlet.
I don't know why this thread makes any difference to anyone except the thread originator who is trying to prove that the outside tips also flow exhaust. I don't think they do.
Old Jul 30, 2010 | 02:10 PM
thedudeman321
Yeah, yeah I get that part. But I want a test that proves to me that its the outer tip flowing a small amount of exhaust that created this effect. I doubt it has anything to do with it.
Old Jul 30, 2010 | 02:11 PM
uptown193's Avatar
uptown193
they don't exhaust anything noticeable. they just there to help with the drone. As seen in the OP first pic of the thread.
Old Jul 30, 2010 | 02:14 PM
  #33
uptown193's Avatar
uptown193
I have these mufflers and they flow barely nothing from the outer tips. Its like putting you hand near a newborns nose, you feel a lil but not much. But they sounds great, no drone and they are still dual exhaust. So if you want tru-dual with exhaust from all 4 tips these are not for you.
Any information needed more than this will be like beating a dead horse.
Old Jul 30, 2010 | 08:06 PM
  #34
GKK's Avatar
GKK
Did you watch the Video?
Watch it again. If there was no exhaust flow from the outer tips, the engine would not run. The tips don't get dirty because the flow is Very Minimal.
I'm tired now....I'm going to Grill some Steaks!
Old Jul 30, 2010 | 10:14 PM
  #35
uptown193's Avatar
uptown193
