HKX Spring Rate
Old Jul 28, 2010 | 05:19 PM
dan_t's Avatar
dan_t
Default HKX Spring Rate
Can anyone confirm the spring rate of the HKX 85-87 front spring? On a list I found on here I keep finding 39.9 - but on the charts like this http://www.idavette.net/susp_chart.htm a spring that soft isn't listed for the front... and would also mean same rate front and rear
Old Jul 28, 2010 | 07:23 PM
rodj's Avatar
rodj
Where did you find the 39.9lb front rating from?
In all my listings it only appears as a rear spring rate
The factory parts book only lists 3 different springs for the '87 front
Coupe base :HKX HMP
Z51 :HMZ
Vert : HMZ
which ties up with what Hib has listed
Old Jul 29, 2010 | 02:57 AM
dan_t's Avatar
dan_t
http://forums.corvetteforum.com/c4-t...ing-codes.html
in a thread you started... this is the same list that keeps popping up. odd that its not been questioned before.
Old Jul 29, 2010 | 03:58 AM
rodj's Avatar
rodj
Didn't get a good response from our resident spring expert when I posted it in another spring thread
http://forums.corvetteforum.com/1553603688-post8.html
Try
http://www.tubas.net/vette/spring-codes.xls
Old Jul 29, 2010 | 09:05 AM
dan_t's Avatar
dan_t
The Rate is left blank on that Excell File...
I will have to check whats on my car right now, when I can get it up in the air
Edit to say: Everything looks like it'll be 51.8 and at the moment I SHOULD have a 54 in my car.
Old Jul 29, 2010 | 09:13 AM
dan_t's Avatar
dan_t
5. Fronts should be compatible across all years, Rears probably 84-87, 88-96 specific
Just a note to anyone that reads the Excell file... that statemet is WRONG. Front springs are different, Rear springs are the same throughout.
To HKX Spring Rate
