EGR/AIR delete question
Old Jul 29, 2010 | 11:37 PM
C4vettrn's Avatar
C4vettrn
Default EGR/AIR delete question
I know this has been discused before but aving a hard time finding info with search button. Does anybody have good info saved they can share or lead me in the right direction? THANKS!
Old Jul 29, 2010 | 11:43 PM
Jamie Lennartson's Avatar
Jamie Lennartson
I donno im installing an HSR with no egr or AIR but headers have AIR im just going to plug them.
Im sure you can do the same to what ever you got.
Old Jul 29, 2010 | 11:46 PM
stevie1dr's Avatar
stevie1dr
I installed the First Injections system and it came with a plug for the EGR. I pluged it and it runs just fine without and egr.
Steve
Old Jul 30, 2010 | 06:32 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
This is what my egr and air delete look like on my 87
Old Jul 30, 2010 | 09:41 AM
rodj's Avatar
rodj
AIR ;
you just remove everything and plug the AIR headers on the exh manifolds.
You need the pump eliminator shown if you wish to remove pump altogether
Some just break the internal vanes out and leave it as a big idler pulley
EGR ;
if your EGR valve is good and not leaking you can just remove the vac line from the EGR solenoid so it won't operate.Saves having to dismantle intake to remove valve and install block off plate.The block off plate for rear of intake shown above is more for cosmetics than anything because if EGR valve is sealing; nothing can flow through that port.
Obviously you need to seal the flange on the exh manifold if you remove the crossover pipe.
To EGR/AIR delete question
