160 thermostat
Old Jul 30, 2010 | 10:24 AM
matt_jahn's Avatar
matt_jahn
Default 160 thermostat
Anyone have the part number for one. The dealer said I need part number or to know what vehicle uses that thermostat. They only have. 180 when they search 92 corvette
Old Jul 30, 2010 | 10:33 AM
PDQUIK95's Avatar
PDQUIK95
From: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
That's because it is an aftermarket non-factory part. GM never offered or installed one. Try Hypertech, MAM, or Ecklers.
Rick
Old Jul 30, 2010 | 10:47 AM
matt_jahn's Avatar
matt_jahn
Well I tried oreillys and they just looked up 92 corvette and said it's 180. So what do I ask them for
Old Jul 30, 2010 | 10:54 AM
markKlein's Avatar
markKlein
If you really want one (I don't know why you would), you can order one fron the Vette websites, Eklers, MAM, Corvette Central or Corvette America.
Old Jul 30, 2010 | 11:49 AM
matt_jahn's Avatar
matt_jahn
thought that is what everyone was doing to make it run a little cooler
Old Jul 30, 2010 | 11:52 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
No, just a few who don't understand what a thermostat does. You will have to lower your fan on temps as well to make any diff.
Old Jul 30, 2010 | 01:45 PM
jnealg's Avatar
jnealg
unless there is a problem you should not need a 160 them.
if there is a problem then it should be repaired. a therm is simply covering the symptoms.
then again if you just like to tinker with things go for it.
Old Jul 30, 2010 | 01:47 PM
uptown193's Avatar
uptown193
OMFG not again............
http://forums.corvetteforum.com/c4-t...hermostat.html
Old Jul 30, 2010 | 02:05 PM
jnealg's Avatar
jnealg
Originally Posted by uptown193
Well my point was/is not directed to those trying to eek out that extra 1/10th sec on the track or those that like to tinker.
Its more to those that freak out at the designed spec of running at higher temps than most cars we have learned on over the years.
It seems folks are looking to spend the extra dime to get a therm instead of pulling the rad and cleaning it out.
just my 2 cents. if it aint broke, dont fix it.
Old Jul 30, 2010 | 02:38 PM
uptown193's Avatar
uptown193
Old Jul 30, 2010 | 02:51 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
When I did mine I just went to Autozone and asked for a 160 SBC thermostat. I believe all small block use the same t-stat.
Old Jul 30, 2010 | 03:20 PM
Ludo 1's Avatar
Ludo 1
6th Gear
i live in holland and we find usa cars to run very hot.
in europe there is no car that runs over 190.
for me when i by american i put in a 160
Old Jul 30, 2010 | 03:59 PM
2012 coupe's Avatar
2012 coupe
Please read below on how they DO work:
Old Jul 30, 2010 | 04:11 PM
BADDUCK's Avatar
BADDUCK
The forum name for that company is HYPERCRAP !
Old Jul 30, 2010 | 06:07 PM
RLG's Avatar
RLG
there are times when you need to run a 160.
one of those times are when your tuner tells you to.
Old Jul 30, 2010 | 09:51 PM
STL94LT1's Avatar
STL94LT1
That worked for your car, but the OP has an LT1 that takes a different stat.
Old Jul 30, 2010 | 10:00 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
yep, noobs dont know how to use the search tool
To 160 thermostat
Old Jul 30, 2010 | 10:11 PM
uptown193's Avatar
uptown193
I know it gets so old to read the same thread over and over. I am not trying to say that the OP thread is old but why can't you just answer his question. If you do no know where to get it don't respond.
To the OP, there is a search button in the red banner just above this thread. It works wonders. I started to use it and I usually find what I am looking for.
Old Aug 3, 2010 | 04:27 PM
David Joseph's Avatar
David Joseph
Default 160 degree stat
guys, if you run your a/c all the time like I do in Florida, then a 160 stat will be (and has been) a huge benefit. Think about it.
Old Aug 3, 2010 | 04:40 PM
BADDUCK's Avatar
BADDUCK
OK I thought about it.......I guess you will have to explain the HUGE BENEFIT. BTW the heat index here right now is 112* with air temp at 103*, and I have been running with a 195* stat just fine.
