Last week there was a thread on sources for new bolts to lower the rear. Does anybody know the size and length of the STOCK BOLTS? Anybody have a source other than the standard supply houses?
When I replaced the rear U Joints I noticed corrosion on both from water gathering around the rubber, something that should be checked on the older C-4s.
thanks
Barrier :)
Northwest Fasteners
Po Box 92038
Tillicum Wa. 98492
253-582-1671
The bolts are automotive size bolts so most fastener warehouses will not carry anything that long.........
The Bolts that you want are 9/16-12 X 10 grade 8 $4.80 ea
and 2 nlylock nuts $.50 ea.
Give them a call and they can get them for you. They allways have them in stock :yesnod:
praise the lowered :crazy:
