DTC #36: Distributor Ignition System High Pulse.
Old Jul 31, 2010 | 12:54 AM
simple green's Avatar
simple green
Default DTC #36: Distributor Ignition System High Pulse.
Had this pop up yesterday when I was beating the 94. Can anyone explain what it means? Thanks,
Cheers!
Old Jul 31, 2010 | 03:46 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
I think it means the ecm thinks it has detected a fault with the Optispark system mounted at the front of your engine and driven by the camshaft.
I presume the system generates an electrical pulse every time the optical sensor gets a light signal as the camshaft rotates. High pulse could mean that the electrical circuit generating the pulse is generating too high a voltage.
Old Jul 31, 2010 | 09:26 AM
rodj's Avatar
rodj
Is code C or H?
A fault has been seen in the Optispark High resolution circuit.
Opti has two different outputs; a low and a high
http://shbox.com/1/95_ign_system_schematic.jpg
Old Jul 31, 2010 | 09:57 AM
STL94LT1's Avatar
STL94LT1
Check the opti's wire harness for corrosion.
Old Jul 31, 2010 | 10:34 AM
simple green
Right on! Will do thanks for the input
To DTC #36: Distributor Ignition System High Pulse.
