up shift light ques
I believe the way the light works is based on a RPM vs SPEED table and a combination of throttle position and time.
For example, if you are in 3rd, at a steady speed, and say 10 seconds the light will come on. But if you are accelerating in 3rd for 10 seconds, the light will not come on. Also, if you are deccelerating in 3rd for 10 seconds the light will not come on.
I recently upgraded my 86 from 700R4/3.07 D36 to a ZF6/3.45 D44 and the light behaves perfectly before and after. The light will come on until I hit 6th gear, anytime that I am steady state in any gear 1-5 for about 10 seconds. The ECM cannot know that I have a ZF6, as there is no inputs for it (and I connected all the required wires myself).
Had I left the 3.07 D36 in the car, the light likely would not have come on in 5th, as the RPMS would match the 700R4 in 4th.
Make sense?
Tom Melton
82 CE
86 Z51 Coupe
Hypothetical constant here: 28.6
2000RPM/55MPH = 36.7 higher than constant - turn on light
2000RPM/70MPH = 28.6 equal (auto 4th with 3.07) - no light
2000RPM/35MPH = 57.1 higher ... turn on light
Again, the above is a simple *possibility* of the way it *could* work.
Last question, did you have your chip in the ECM modified for your grar change? If not, then find someone to burn you a new chip with the correct ratio and the light will probably start working correct again.
Tom Melton
82 CE
86 Z51 Coupe
Tom Melton
82 CE
86 Z51 Coupe[/QUOTE] His is an 86-it just needs the gear/gears on the tranny speed sensor changed to correct the speedo signal to the dash and the ecm.
-Tom
Couldn't they have programmed the PROM to deactivate this light on the automatics? Oh well, then their would have been two different chips for manuals and automatics.
Sorry, didn't mean to rant.
ThermoMaster Power Chip 5.7 TPI AH AUTO FED 126022
ThermoMaster Power Chip 5.7 TPI CIH AUTO FED 126032
ThermoMaster Power Chip 5.7 TPI CIH MAN FED 126042
ThermoMaster Power Chip 5.7 TPI AH MAN FED 126062
ThermoMaster Power Chip 5.7 TPI CIH AUTO CAL 156302
ThermoMaster Power Chip 5.7 TPI AH AUTO CAL 156342
ThermoMaster Power Chip 5.7 TPI CIH MAN CAL 156372
ThermoMaster Power Chip 5.7 TPI AH MAN CAL 156382
Note though that Hypertech does not differentiate between the non-performance and performance axle ratios. To fix the light will typically take custom programming -OR- remove the bulb.
-Tom
