LT1 steam tubes
Old Aug 2, 2010 | 07:41 PM
surfer93's Avatar
surfer93
Default LT1 steam tubes
Anybody know where I can pick up a tube?
Old Aug 2, 2010 | 08:03 PM
JAKE's Avatar
JAKE
Ecklers usually carries a lot of low demand replacement LT1/4 parts.
I've read of guys fabricating them. If there are no posts on that here at CF, you can try LS1LT1.COM and CamaroZ28.com; those guys run a lot LTs too.
I've never checked at stores like NAPA, but they're worth a try.
Hope this helps.
Jake
Old Aug 3, 2010 | 11:19 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Let us know if you find anything.
I'll be looking around the first of the year for parts to finish my engine build.
Old Aug 3, 2010 | 11:37 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
If you know what size fittings, you can call up either Russel or Earl and fab a braided line.
Old Aug 3, 2010 | 01:53 PM
surfer93's Avatar
surfer93
Who are Russel and Earl?
This is the tube between the 2 heads, not sure if you could fab a line for that.
I checked autozone and such with no luck, not a dealer carried item, I will look at Ecklers again.
Old Aug 3, 2010 | 02:05 PM
BrianCunningham
http://www.russellperformance.com/
Earls owned by Holley
http://www.holley.com/index.asp?Division=Earls
Old Aug 3, 2010 | 02:47 PM
JAKE's Avatar
JAKE
Sure you can. Those two companies make hoses that are specifically designed to handle a LOT more pressure and higher temperatures than your coolant will ever see.
You're only looking at low to mid 200F coolant temps and 15 psi or less in pressure.
Jake
Old Aug 3, 2010 | 06:24 PM
surfer93's Avatar
surfer93
Jake
I know that, but doen't the coolant travel around the bolt?
Old Aug 3, 2010 | 07:29 PM
BrianCunningham
on a banjo they go through the bolt
http://en.wikipedia.org/wiki/Banjo_fitting
no rise in pressure if that's what your asking.
To LT1 steam tubes
