84 Transmission Problem
Old Aug 4, 2010 | 11:42 AM
sgtbrum383's Avatar
sgtbrum383
1st Gear
Default 84 Transmission Problem
I have an 84 with the 4+3 Doug Nash transmission. The problem is when the engine is running the transmission will not shift into or out of gear. With the engine not running the gears shift fine. About a year ago my overdrive quit working. Could the overdrive unit going out cause the tranmission to fail? Both cluth master and slave cylinder has been replaced. Any information would help. Thanks
