Permanent Fuel Pressure Gauge - Useful Mod
Old Aug 10, 2010 | 08:45 AM
  #41
dclafleur's Avatar
dclafleur
Originally Posted by SJW
This advice is dead-on. I would NEVER permanently connect a mechanical FP guage. The Bourdon tube inside of the gauge can indeed fatigue, and when it does, things can get exciting real fast.
I don't even trust the electric senders to not leak, as I've replaced many electric oil pressure senders because of leakage, and I'd expect their construction to be similar to an electric sender for a FP gauge.
If you're trying to troubleshoot a problem, temporarily tape a mechanical gauge to the windshield, as has been suggested here already. For most of us, that's all we'll ever really need. It really isn't necessary to monitor FP at all times on a street-driven car.
Stay safe, y'all. Engine bay fires are ugly.
Live well,
SJW
Does anyone make a fuel pressure gauge with a longer hose? closest I can tape mine is to the bottom of the windshield where I have to bend my neck over to be able to see it.
Old Aug 10, 2010 | 10:21 AM
  #42
qws's Avatar
qws
Originally Posted by rodj
IIRC ;Fuel valve has Viton fuel resistant seal
You use the same rail adapter to mount the 1/8"NPT sender unit for the elec gauge , then run a wire inside to gauge located where ever you want.
Your choice;
analog
http://www.summitracing.com/search/P...L+GAUGE&RC=100
or digital
http://www.summitracing.com/search/P...ord=FUEL+GAUGE
Pod mount maybe
thanks for answering the question about the schrader valve. Never knew what the differance was. Before I installed the gauge everyone around here wanted to sell me a tire schrader valve. Figured there was a differance but wasn't sure.
I'm liking the idea of a electronic gauge inside the cockpit... maybe be a winter project....
Old Aug 12, 2010 | 12:20 AM
  #43
SJW's Avatar
SJW
Check out Actron's offering. See if the hose is longer than the one you have. Probably is.
Live well,
SJW
Old Aug 12, 2010 | 04:35 PM
  #44
C4vettrn's Avatar
C4vettrn
Default cap?
Where can a guy find a cap to fit the schrader valve? Mine was plastic and it broke. They are way bigger than ant tire valve caps I have ever seen?
Old Aug 12, 2010 | 11:37 PM
  #45
JAKE's Avatar
JAKE
Long hose FP Gages: I'd check SUMMIT, JEGS, TPIS, ECKLERS, and probably others too.
Cap for Schrader valve: ECKLERS; they sell lots of low-demand parts. You can hit Mid-America and CorvetteCentral too.
Jake
