Modding the Stock FPR
Old Aug 5, 2010 | 09:21 PM
JAKE's Avatar
JAKE
Default Modding the Stock FPR
Has anyone modded their stock LT1 Fuel Pressure Regular to increase it's pressure output? Could save me $80 for the Accel model.
I recall some guys did that to their L98 FPRs by installing a washer/shim but haven't come across anything on the LT1 version.
Thanks,
Jake
Old Aug 5, 2010 | 10:43 PM
mseven's Avatar
mseven
The one that tpis uses for the mini-ram is a lt-1 frp. The only difference to make it adjustable was they cut the top part off the fpr to fit the cap with screw, they add a shim and use a type of band clamp. You could buy just those parts from them and mod yours.
Old Aug 5, 2010 | 11:28 PM
JAKE's Avatar
JAKE
Thanks for that. I've got a spare one; maybe I'll play around with it since apparently no fuel flows in the adjustment area. Won't have to worry about leaks.
If I run into anything I'll get back to you.
Jake
To Modding the Stock FPR
