I have a 1994 LT1 corvette and have change the diff. from a 259 to a 354. In addition to reprogramming the computer do I also have to change the (reluckter ring)(sp.) in order for the car and the speedometer to perform correctly
yes the speedo gear on the trans tailshaft has to be replaced,a few members done this deal and could chime in on the correct gear.good luck and bye the way how is the performance with the new gears?greg84
I have a '93 and I'm going from 2.59s to 3.54s next month. These are the speedo parts I had to order...
My new gears came in today. I am upgrading from 2.59 to 3.31's.
I have a 1995 w/auto tranny. I am running the stock tire size in the rear.
What do I need to do to correct my speedometer. I do have the hypertech
III, but the 3;31's are not listed...Thanks in advance :confused:
id call hypertech or youll have to have it custom flashed
I was wondering if you checked into the speedo calibrator that Zip products has out for the 93's. I am in the process of doing the same gearing change and I was told that this calibrator was much more accurate but it cost me around $160.
I answered your e-mail that you sent me before I read this thread. On mine it is different, 93 and earlier use gears and a sensor. On yours, I believe it is simply a program change. No need to change any mechanical parts.
What sensor is this? I contacted 18carfan (who I ordered from) and he told me that I only needed two gears and the rear tranny tail seal. :confused:
Thats strange. 18 carfan is who sold me mine. When you change the 2 gears, the spacing between them no longer aligns with the old sensor. So a new sensor has to be used which has a different spacing. Now the sensor I am referring to is the one that the driven gear goes in and the wiring plugs into it.
That would be the VSS (Vehicle Speed Sensor) I did the same thing. Green gear, red gear and a new VSS.
I just did this last night and went form 2.59's to 3.07's in my 88. I ordered my parts from 18carfan also. I got the VSS and a green gear. It wouldn't fit the old VSS because you are using a bigger gear so the shaft in the VSS has to be offset to compensate. Unfortunately, the one I got didn't work either untill I spun it 180* to put the offset where it needs to be. I don't know if I was sent the wrong part or if I am just lucky and got a defective one but it caused me a giant MF'ng headache untill I figured it out.
It depends on driven gear that you have or are changing. In general 3.07 owners upgrading to larger gear don't need a new VSS, while 2.59/2.73 owner need a new VSS. The larger Vss fits 40-45 driven gears and smaller VSS fits 35-39 tooth driven gears
Use the closest gear ratio in the Programmer and use tire size (height) to adjust.
For the 94, I found that the 3.45 gear ratio in the programmer worked best with the 3.54 gear.
