94 service engine light
If I was driving slow it would die but restart after some cranking.If I was driving faster it would just stall momentarly but keep running. The A/C would stop blowing cold after the light came on. The last codes I got were H72,H36,H42,&H62 . I cleared these codes once but H 62 would not clear. (Engine oil temp sensor circut voltage low.) Last time I drove the car I barely made it home. It started back firing badly. When I got home I noticed what looked like a ceramic pellet resting in the exhast tip (catalytic converter?) Also the top radiator hose was expanded and some rusty water had sprayed out,I let the water get rusty so I need to know the best way to flush the whole thing out. I also put an MSD opti spark in and I noticed the intake hose was loose and I'm wondering if it sucked any crud into it.That would make it back fire for sure,anyway any help would be apreciated.Rick
