valve adjustment with diff cam
Old Aug 10, 2010 | 08:07 AM
jdraughn's Avatar
jdraughn
Default valve adjustment with diff cam
can anyone tell me how many turns past zero valve lash my valves should be adjusted with a zz9 cam and everything else stock (except for the lifters of course). is it still standard 1.5 turns?
Old Aug 10, 2010 | 08:33 AM
cv67's Avatar
cv67
St. Jude Donor '05
1/2 to 3/4 turn avg no,need for more.
Old Aug 10, 2010 | 08:44 AM
JAKE's Avatar
JAKE
No, no, that's too many turns.
When I ran the TPiS ZZ9 in a 355 CID TPI 86 Vette I set the preload at 1/2 (one half) turn past Zero lash using CompCams Hydrauic Roller Retro-Fit lifters. This was the CompCams recommended preload for those lifters and, also almost all of their other HR lifters too.
Remember, it's the lifters that call for a certain preload setting, not the cam. Different lifters can call for different preload recommendations. Comp's "R" lifters are an example which, last time I checked, called for .002"- .004" of preload - which "ain't" much at all.
Jake
Old Aug 10, 2010 | 09:00 AM
jdraughn's Avatar
jdraughn
thanks, looks like i need to research some. its running pretty good right now but it has a little clatter. thats with one full turn past zero valve lash. i need to find out exactly what lifters i have, they came used with the engine.
Old Aug 10, 2010 | 10:21 AM
PDQUIK95's Avatar
PDQUIK95
From: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
Jake
Ditto
I currently run the Comp "R" lifters an it is only about half of a flat on the poly lock hex nut using 7/16"-20 studs.I ran the ZZ9 cam in my 383 and used 1/4 to 1/2 turn with standard CC roller lifters primarily because I drag race the car and turn it up to 6400 quite frequently. A half to 3/4 should be all that is necessary for normal driving conditions with standard roller lifters.
Rick
To valve adjustment with diff cam
