Looking for step by step instructions for a/c compressor replacement on 1994
2) Keep all openenings to atmosphere covered with a plastic baggie and rubber band until you are ready for re-install
3) replace any "O" rings you come across
4) coat new "O" rings with correct PAG oil before install
5) Tighten all Line connection snuggly, but don't King Kong them
6) Getting old oriface tube out will be the hardest job. They are wedged in there, and won't just pop out. Suggest a small investment in oriface tube removal tool.
7) Yes, you need to rent or buy a gauge set and vacumm pump. Harbor Freight sells a decent 2.5CFM vacymm pump a cheap gaue set. They work fine for the occasional AC DIY'er .....Do not skip the vacumm step. You need to remove all air/moisture before charge. After vacumm, let system sit idle for 1/2 to 1 hour and make sure no leaks.
8) You will need to add some PAG oil as well as R134a. Your old compressor and receiver/dryer will have residual oil in them that you will need to replace. Try to drain them and measure amount that is lost. New oil should be added directly to compressor prior to install. After install turn compressor by hand a couple dozen times CC and CCW to distribute oil in pistons.
http://www.amazon.com/Interdynamics-.../dp/B002G1UNEO
Oil Capacity is 8 ozs. Flush what's in the new compressor by draining what came in it. Fill with 4 ozs and crank the shaft as outlined. Drain and repeat leaving 4 ozs in it.
Most of the oil is usually in the Accumulator so whatever drains out, add back in plus an ounce. Put an ounce in the orifice hole.
All needed is the application of common sense and care, like first relieving the pressure at the Schrader valve (just as you would with the fuel system) covered with towels/rags, etc.
I mean, GEEZZ, Come-on, ...
Jake
