I took the radio bezel off and there is a relay with an orange and two gray wires it also has a metal wire clip on it to make sure the plug does not come off. what is this relay for???
The picture above shows the Lateral Accelerometer used by the ABS.
According to the service manual.
Provides a signal used by the EBTCM which reflects the severity
of a vehicle turn. This information is used by the EBTCM to
modify the control of the rear wheel brakes to help prevent
loss of control during a turn due to rear wheel lockup.
The AC compressor clutch relay is located below the left hand
side of the instrument panel, left of the steering column.
The relays in that area are all the same so they can be swapped around
for test purposes.
If the compressor clutch is not engaging due to a low freon code being set,
disconnecting the negative battery cable will reset the AC system so the
clutch will engage until another code is set.
