Coolant leak
Old Aug 12, 2010 | 06:13 PM
Chapindad's Avatar
Chapindad
Default Coolant leak
I have a coolant leak on a valve next to the firewall where the pipes go to the heater core. It leaks right on the valve where it opens and shuts. Can I take it apart and fix or do I have to replace the entire pipe which would be easy enough but I have not found a place to purchase it yet.
Old Aug 12, 2010 | 08:10 PM
JAKE's Avatar
JAKE
I can't say if the part will need replacing because I can't see what we're dealing with, but if it comes to the point that you need a replacement part, ECKLER's sells a LOT of less-demand parts for our engines.
Their catalog is on-line.
Hope this helps.
Jake
Old Aug 13, 2010 | 11:59 AM
Chapindad's Avatar
Chapindad
http://gallery.me.com/chapindad/1000...12817148920004
Here is a picture of what is leaking. I have looked through Ecklers twice and can not find the part. Doesn't mean it is not there but I can not find it.
Old Aug 13, 2010 | 12:20 PM
Chapindad's Avatar
Chapindad
Is this the part?
http://www.ecklers.com/corvette-hot-...1986-1987.html
Old Aug 13, 2010 | 12:36 PM
Chapindad's Avatar
Chapindad
Never Mind. Once I found the part name, I found the thread on here.
http://forums.corvetteforum.com/c4-t...-corvette.html
To Coolant leak
