Anyone using 4" trans pans..
Old Aug 14, 2010 | 09:53 AM
twin540's Avatar
twin540
Default Anyone using 4" trans pans..
I was told I would only have a 2" clearance . shime in if you have or have'nt
Old Aug 14, 2010 | 12:19 PM
85vet's Avatar
85vet
Cruise-In V Veteran
I have the deeper pan recommended by the tranny builder. To give the exact inches, I would have to measure it. I have not had any problems for 3 years and the pan is no lower than my 7 quart oil pan.
Old Aug 14, 2010 | 04:21 PM
twin540's Avatar
twin540
Good. I ordered a derale /patc pan , In this texas heat I'm trying to cool the temps as much as possible.
Old Aug 15, 2010 | 08:58 AM
mseven's Avatar
mseven
The derale has good clearance for a deeper pan (think it's a bit less than 4"), depending on car height. The front of it is the lowest point, but not too bad. It does sit lower than the canton r.r.oil pan.
Old Aug 15, 2010 | 11:33 AM
twin540's Avatar
twin540
Thanks for the imput. Mseven
Old Aug 15, 2010 | 11:51 AM
Calderone's Avatar
Calderone
Hi,check this thread and this thread,those are my experiences
Derale pan is one of the best mods i've ever done !
Old Aug 15, 2010 | 01:35 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Don't do it if you plan on lowering your car. Mine is lowered and I have to be careful when going over dips in the road. The first thing that scrapes is my rear exhaust.
Old Aug 16, 2010 | 05:38 PM
twin540's Avatar
twin540
Thanks calderone
Old Aug 16, 2010 | 07:39 PM
Calderone's Avatar
Calderone
Originally Posted by twin540
Thanks calderone
You're welcome !
Old Aug 16, 2010 | 10:15 PM
mcm95403's Avatar
mcm95403
Those are great links! We used those Derale style trans pans 25 years ago and they always worked awesome. Never had one leak anywhere, even when dented.
When I get time to do a fluid change in mine I'll pick one of those up.
Old Nov 5, 2010 | 09:29 PM
twin540's Avatar
twin540
Not that much lower than my exhaust..
Old Nov 8, 2010 | 02:10 PM
aklim's Avatar
aklim
I know on the Ford boards, there are a lot of arguments about how a deep pan helps. Unfortunately, that is a theory only since they had a Ford engineer who worked on transmissions do actual tests with sensors and showed that the deep dish did nothing for cooling in that vehicle.
Anyone know if we have conclusive proof one way or the other instead of just guesswork?
To Anyone using 4" trans pans..
