Clearing Codes
Old Aug 14, 2010 | 10:30 AM
8valve's Avatar
8valve
Default Clearing Codes
Is it possible to clear codes using either Tuner Pro RT or WINALDL ? If so I cant find it in either program.
8Valve
Old Aug 14, 2010 | 10:52 PM
rodj's Avatar
rodj
Not that I am aware of, usually just disconnect the battery
Old Aug 14, 2010 | 11:16 PM
8valve's Avatar
8valve
Ok, thank you
8Valve
Old Aug 15, 2010 | 08:47 PM
chrisb29's Avatar
chrisb29
8th Gear
i am useing a $6e and arap bin for a 165 ecm, in tunerpro rt you can clear codes in the aldl datalog setup screen,sometimes, not always after you send command to clear codes you have to cycle key off wait a few seconds then on and codes will be gone. hope this helps you. thanks chris b.
Old Aug 15, 2010 | 09:14 PM
8valve's Avatar
8valve
Chris, thank you. Somehow I kept missing it. Got it now.
8Valve
Old Aug 16, 2010 | 07:24 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Pulling the ECM fuse for a few seconds is a lot easier
Old Aug 16, 2010 | 08:08 PM
8valve's Avatar
8valve
Yes, good easy way, Thanks
I see your upstate NY. I am at Schroon Lake (Adirondack Mts). If you ever get in that area, PM me and stop by.
8Vakve
To Clearing Codes
