Bad running 89
I have 38-42 lb fuel pressure at the shrader, and she holds pressure after shut off.
All injectors ohm at mid 12 to low 13 hot and cold.
No codes thrown.
Just did a full tune cap rotor wires and plugs still no better.
How can I tell if I have clogged injectors or weak ignition?
No codes thrown.
BTW, your Ohm readings on the injectors sounds low to me. (I typically expect no less than 14+ Ohms hot.) If they are the original Multecs, check with Jon at FIC for his replacement injectors. Better metering for better mileage and power!
That said, pull your plugs, and do some plug reading.
a rough idle may indicate bad plugs, vacuum leaks, misadjusted throttle body, bad grounds, leaky injectors, timing can be off, poor computer solder joints, bad oxygen sensor,etc.
just for grins,
1. there is a vacuum check valve at the back of the engine for the cruise control. pinch that off, and see if there is a change.
2. pinch off the PCV valve and see if there is a change.
3. pinch off the vacuum line that goes to the charcoal cannister, look for change,
4. loosen and tighten the engine ground at the back of the engine on the right side.
5. disconnect the spark control module located by the heater and see if it is better.
6. pull off the air filter and see if there is a change.
7. make sure the valves are adjusted. one nut tightening itself due to a poor lock can cause a valve to begin hanging open
8. Get creative...... what would you be missing for a smooth idle if you were an L98?
Jon's the MAN.... call him if you need good advice They are grey.
