Which TPI throttle body replacement?
Old Aug 15, 2010 | 02:19 AM
TheFinn's Avatar
TheFinn
Default Which TPI throttle body replacement?
Hey.
My throttlebody is worn out and tends to stick leaving high idle until I tap the pedal. It also requires extra effort to press resulting in bouncy drive. I don't have possibility to repair this one - don't know if it even can be done so
What would be recommended replacement throttle body to get?
Old Aug 15, 2010 | 04:26 AM
rodj's Avatar
rodj
Places in the USA rebuild them
This place will sell you a rebuilt TB outright with no core charge and they ship international
http://cgi.ebay.com/ebaymotors/TPI-5...Q5fAccessories
Old Aug 15, 2010 | 05:35 AM
TheFinn's Avatar
TheFinn
Outstanding link. Cheers mate.
Old Aug 15, 2010 | 08:07 AM
Ludo 1's Avatar
Ludo 1
6th Gear
did they not change the TB when going from MAF to MAP. if so get the richt one
Old Aug 15, 2010 | 08:19 AM
rodj's Avatar
rodj
Only the linkage style changed over the years.
Early had stud mount like a carb / later has a pin that fits in a hole and the cable lays around a quadrant
LT1's have a different IAC and TPS
To Which TPI throttle body replacement?
