1/2 lower
Old Aug 15, 2010 | 06:53 AM
stick105's Avatar
stick105
Default 1/2 lower
My 84 is 1 inch lower in the front only. The driver side is 1 inch lower than the passenger side. The rear is the same left to right. The car has new shocks. I measured from the wheel wells and from the far end of the fog light cut outs. It is noticable standing next to the car. How can I fix this.
Old Aug 15, 2010 | 12:25 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
carry a passenger at all times.........
Seriously?
1. switch shocks from Lf to Rf, see if one has less pressure inside.
2. there are spring spacers under the spring cradle to add or subtract thickness
3. new spring
4. There are newer style spring brackets you can get.
The car is supposed to be lower in the front than the rear for aerodynamics.
