Hey guys this 90 Vette only blows out of defrost. The C68 control does not have any codes in it. I'm thinking a/c programmer, anyone think it could be anything else?
As Aurora 40 said check the supply line from the intake manifold, there is a check valve that is notorious for failure, when vacuum is lost defrost is the default mode for directing airflow.
It could potentially be the vacuum lines themselves, or no vacuum source to the programmer.
This is right where I'd start. Especially with no codes. I think defrost is the default (i.e. with no vacuum, defrost will flow), and the opening/closing of the vents is controlled by diverting vacuum on/off to different vents.
I would check for vacuum, with the engine running pull the vac line off of the vac ball located in the front left corner of front bumper, put your finger over the end of the line and feel for suction. if there is none trace the line back for cracks or breaks in the line. good luck..
You know I feel like a dumbass cause I know about the vacuum lines behind the engine are 95% chance whats wrong. Slipped my mind, found a broken line, I'm sure that was it, can't wait to reconnect battery after replacing the impact sensor to confirm.
From: Gaithersburg MD A member since 2007 but then the computer crashed and then the car crash loss of memory X 2
