Rear-end Noise
Old Aug 15, 2010 | 02:20 PM
My1st's Avatar
My1st
Default Rear-end Noise
I’m hearing a low pitch humming/rubbing noise in the rear-end, hard to say what it sounds like. It doesn’t make noise at first just after driving a while. Any ideas?
Old Aug 15, 2010 | 03:04 PM
MotorCity_87_C4's Avatar
MotorCity_87_C4
Check the differential fluid lately?
Old Aug 15, 2010 | 03:37 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Tires ? Carrier bearing ?
Old Aug 15, 2010 | 05:03 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
ujoints and champagne
Old Aug 15, 2010 | 05:18 PM
M. Schumacher's Avatar
M. Schumacher
In addition to what's already been suggested:
Find a smooth stretch of level road and see what happens under the conditions of gentle acceleration, deceleration, and coast.
The object is to observe the noise as you load the differential from both directions and also with no load on it.
Also note if cornering or braking have any effect.
Old Jul 26, 2011 | 10:16 AM
My1st's Avatar
My1st
Still trying to locate the source of the noise I hear (seems to be only at slow speed and while turning) once I have driven about 15 miles.
I replaced the bearing assemblies in the rear but it didn’t change a thing.
Is it possible for u-joints to make a winning noise? I know they need to be changed at least the main drive shaft by the clunking.
Would it be the pinion gear? Checked and added the proper mix but didn’t take much.
Old Jul 26, 2011 | 10:23 AM
navy_vette's Avatar
navy_vette
I vote that it's the rear diff considering it happens when you are turning. One tire is turning faster than the other when you turn and the differential is what balances that.
Old Jul 26, 2011 | 10:51 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Holy thread revival!
Good luck!
Old Jul 27, 2011 | 12:32 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
I've been chasing something similar for almost a year. It takes about 30 minutes of driving to warm things up then the whinning starts. I threw her out one time and confirmed its not the wifey.....
U-joints are not really turning so the sound is unlikely to originate from there.
My guess is the L/R wheel brng but still can't confirm. I'm going to start some tests with a microphone to isolate the sound. Hope to find this annoyance soon.
Old Jul 27, 2011 | 12:52 AM
87 vette 81 big girl's Avatar
Gear oil thins down as you drive for 30 minutes.
Ring & Pinion Gearset start to whine.
Wheel Bearings stay the same pitch or noise level cold or hot driving.
Just my experience as a Mechanic.
Nothing last forever.
Including Ring & Pinion gearsets.
Hopefully I am wrong.
Troubleshoot with a microphone - mechanic's stethoscope yet though.
BR
Old Jul 27, 2011 | 01:26 AM
JrRifleCoach
Hmmmmmmm...... Time to break out the borescope
Old Jul 27, 2011 | 07:39 AM
Naaa,
You could use the Boroscope for checking out the wife.............
Don't get beat up by her..............LOL
Old Jul 27, 2011 | 11:30 AM
JrRifleCoach
Old Jul 27, 2011 | 02:21 PM
My1st's Avatar
My1st
In my case it’s not the bearings I replaced both L&R.
I was told that synthetic gear oil will stop the whining or at least help?
Old Jul 27, 2011 | 08:49 PM
No,
In my experience once a Hypoid Ring & Pinion Gearset starts to whine for whatever reason,
changing over to a synthetic makes the whining noise worse.
I like synthetic gear oils such as Royal Purple 75-90w.
Years ago you could Buy true straight mineral/ dino 140w gear oil.
You could find it at your local diesel repair shops.
It would help some with gear whine noises in passenger cars & trucks.
Its all gone though that straight 140w.
Last time I found 140w was around 15 years ago.
BR
To Rear-end Noise
