SYS flashes on dash!??
Old Aug 15, 2010 | 08:57 PM
VettegettemWet's Avatar
VettegettemWet
Default SYS flashes on dash!??
Had the vette sitting for a couple months and about a month ago I took it out and it flashed SYS every 15 seconds. It died on me because it got too hot and wouldnt start for about 20 minutes. Anyone know what could be causing the SYS to flash?
Old Aug 15, 2010 | 09:28 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
A low battery can cause that.
SYS flashing indicates an electrical issue
Old Aug 15, 2010 | 09:37 PM
ffvetteman's Avatar
ffvetteman
Probably a weak battery. My 92 sis the same thing. I changed the battery and all good.
Old Aug 15, 2010 | 11:28 PM
jimmers's Avatar
jimmers
I had the same issue on my 90 a few years ago. Change the battery.
Old Aug 16, 2010 | 06:36 AM
MTVette's Avatar
MTVette
Me too.
Old Aug 16, 2010 | 09:30 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Yuppers. Sounds like your battery's gone ****-up.
Old Aug 16, 2010 | 10:40 AM
jmgtp's Avatar
jmgtp
Like everyone else says - battery - however, mine did this when the connection on the battery was just a bit loose. I snugged it down and problem solved. Worth a check before running out and buying a battery.
Old Aug 16, 2010 | 10:47 AM
gbrtng's Avatar
gbrtng
Most likely a weak battery but it could be most anything else related to the body's electrical system. Have the battery checked by a reputable shop (even Wally World does this) and if it's OK, scan the CCM for codes and go from there.
Old Aug 16, 2010 | 11:19 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
St. Jude Donor '12
Did anyone mention checking the battery yet????
If mine isn't started every week I have to put the charger on it.
To SYS flashes on dash!??
