Will MAF
Old Aug 16, 2010 | 09:34 PM
Marv02's Avatar
Marv02
Default Will MAF
Will a bad MAF keep my car from starting I unpluged I still can't get the car to start.
Old Aug 16, 2010 | 09:48 PM
Rich Silvestris's Avatar
Rich Silvestris
St. Jude Donor '05
The MAF can prevent a start. Try to start the engine a couple of times after you unplug the sensor, Mine was cranking and catching and dying. but it would catch on the second try after unplugging the MAF (but never the first time). You can also try unplugging the timing connector at the distributor to test for the pickup coil.
marty mar's Avatar
marty mar
Your car will start with the mass air flow sensor unplugged. Your problem lies elsewhere.
Old Aug 16, 2010 | 10:15 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Check for fuel, check for ignition while cranking.
You need spark, fuel, compression, and the mechanical parts to be working.
Check each one of these, and you will find your problem.
Old Aug 16, 2010 | 10:23 PM
Marv02's Avatar
Marv02
Thanks but I KNow I have great spark good compression I ging to out this weekend and pick up a fuel pressure gauge.
The ownner of the local Napa store told me his C4 didn't start due to a bad MAF.
I think it fuel my self.
I going to replace the relay and put a fuel pressure gauge on the car.
To Will MAF
