Installed New Optsparki No Start
but I think it was more than that,but you never know
Ultimately it was definitely more than a battery for sure and Im not to sure this will be the fix but I know I have a lot of bases covered and Im always getting closer ( I must be a an optimist lol )
so I see an oppertunity to pull codes and I get a 16 from the ecu. I then pull the ccm codes and get these three Modual 1 a H54 Modual 4 ( ECM I think ) H16 and a modual 9 H72
When trying to link my code scanner I get the message cannot communicate or something like that, Sometimes when trying to jump the a and b terminal I get a steady light and nothing not even a 1 2 flash and other times I get the codes flashing
I mean thinking about it having cleaned up the grounds by the battery not that they where corroded but also replacing the icm etc at least now the car is starting at times, not that this has anything to do with that
Right now I need to trace out these codes it seems to me like Im not getting communication from ecu to ccm at times and this si when it shuts off. I have heard of others getting their ecm fixed and this solved the problem. I think that is the next step but Im open to any ideas and would love to hear any thoughts on this from others who know about this stuff or who have had this problem. Not giving up I feel closer than ever and yet so far lol nevertheless Im gonna clean some more grounds next also byt eh starter and apply dialetric grease
Also I tried pulling and pushing the wire harness underneath the dash in various places while cranking to see if that would help close any open circuits etc but none of that worked, nor did I hear any electrical systems coming on or shutting off. I suppose this is kind of like a wiggle test while Im at it hoping that wiggling the wires will start the car. I checked the fuses none of them are blown, Hope someone can help me out with some thoughts or experience with what these codes mean. I know 16 is low opti resolution the other 2 I have no idea
Can the opti cause all of these problems or is the problem related to the ecm or between the ecm and ccm? wow I know speak a second launguage come to think of it lol Holy god you need patience for this Ill tell ya that
Mike
So this history error code agrees with the problems you are having.
H16 - Low resolution pulse
This is worrisome. Did you get an AC Delco or MSD or what ? Have heard that some folks have problems with loose rotor screws on the rotor. FWIW, all the Optis I have replaced, I first opened them up, removed rotor screws and loctited them.
Here's how to clear your codes without disconnecting Bat. neg. term. :
To clear the codes,
1. With ignition "off" ground terminal #12 of the DLC (use bent paper clip to connect pin 4 to pin 12)
2. Turn ignition "on".
3. Press trip/odo button on the DIC until 1.7 appears in the trip
monitor area of the instrument cluster.
4. Press eng/met button on the DIC & hold until "---" appears in the
speedometer area of the cluster, this will clear CCM DTC'S.
To clear PCM/ECM codes do the following:
1. Press the trip reset button on the DIC until the desired system is displayed. In this case it will be 4.0.
2. Press trip/odo button on the DIC until the desired diagnostic mode(4.7) is displayed on the trip monitor area of the cluster.
3. Press & hold the eng/met button on the DIC until "---" is
displayed in the speedometer area of the cluster, this will clear PCM codes.
To clear ABS/ASR codes do the following:
Same as above but you’re looking for “9.7” on the trip odo
Does your '94 have a 12pin or 16pin DLC ?
Mine has the 16pin(system is still OBDI though)......hence short #4 and #12
if 12pin ........Short A&B
My guy at pep boys can send it to Borg Warner overnight and they will look at it and make repairs for a 127 bucks. Anyones thoughts on this or any other ideas as for getting one. I just lost an opt on ebay for a buy ot now on one but Im open to suggestions. The car ruuns excellent all the functions work the clutch is tight, reverse is good. I want so badly to take it down the block but no way. I live on myown and would not want to get stuck out there. I had a mother of a time getting this back into my spot when it would not start back up today. Also I believe cleaning those contacts at the opti harness helped a lot. I used a pointy little metal dagger with the tip bent slightly and scuffed the inner walls of the metal contacts. This is where the harness meets the opti. I was never a fan of cleaning contacts grounds etc but I am now lol and Im gonna do the same tomorrow with the ecu male connectors
Wow I almost certain this is the problem and I have isolated it. also when its running right there are no service lights on the dash at all. This should be made a sticky oneday lol. I worked my *** off to get this done. Imust have pulled all the fuses at least 3 times. I brushed up as many of them as I could and applied dialetric grease to all battery posts and grounds I could find. I must have traced a ton of wires for faults voltage continuity etc Ultimately I did not want to bring my car on a tow truck to the stealership
Keeping my fingers crossed lol
your the best. Thanks so much for following me on this post. I have relied heavily on your inputs and have always looked to see if you chimed in. Thank you so much. Read my above comments and tell me what you think
Mike
Keep us posted !
-Al
Keep us posted !
-Al
Of course this may not be the end of it or the problem but Im pretty sure as you mentioned that if I can knock the car off by tapping the ECU its a no brainer that something is up with that. Ill send it out with all of this info codes and symptoms and go from there unless I can get a good deal sooner on one. Ill definitely keep you posted. Hopefully it will all work out:
Mike
Do you think excess noise, vibration, and harshness (NVH) might have contributed to its demise?
Nice Motor lol ZR1 Better keep that baby tip top lol With that no I dont think there is a need to provide further shock resistance. The plastic tray is pretty flexible although with colder ambient temps that would change. So I might add a rubber grommet or two. Heat probably effects them but so far they seem pretty sturdy. Id say the biggest issue is not to put anything on top of the ECU and then shut the hood and definitely don't punch it as I suspect this fellow who owned it previously did out of frustration ( he was pissed when I came to get the car thats for sure ) He either closed the hood on it with something on top or punched it, there was a definite dent and the Board and its accompanying circuits are not even a half an inch within touching the top of the case. So with that Id say if anything, dont just slam your hood. Id close it nice and gently. Letting it down nicely and then just pressing the corners lightly to close each one. I will not let my hood drop closed no way, that I definitely would not trust lol
Mike
I don't know for sure but it seems logical for them to have tested for the effects of dropping the hood, etc. since that's what GM recommends as the way to close it.
However, since it's been mentioned it makes good common sense to minimize or eliminate as much shock to the PCM as can be. So NOT dropping the hood, to me, is the best plan out of the two options.
I hadn't even thought about this before, but am glad it was brought up. I know which way I'll begin using to close my hood from now on.
Thanks for that.
Jake
