Code 41 Cylinder select error...please help
Old Aug 18, 2010 | 11:03 AM
Yesterdayscorn's Avatar
Yesterdayscorn
7th Gear
Default Code 41 Cylinder select error...please help
Need some help/advice......I'm getting a code 41 cylinder select error and the car barley runs.
History.....car sat for about 8 months dead battery, changed battery and fuel pump took a crap changed it and a week later the pump took another crap....hummmm. Found fuel pump relay was bad and wires were shorting out. Rewired and changed relay and car seemed to run ok but was getting intermittent service engine soon light. When the light was out car ran great as soon as light came on ran like crap.....as days went by the more I ran the car the crappier it would run, the mechanic around the corner pulled the code (41) and said i prolly had a bad ECM we replaced it and no difference, put the old ECM back in and limped it home......car seems to be running very rich and will hardly go at all.
Any suggestion would be great, I'm at a total loss....mech said it could be a bad PROM ???
Thanks for any comments/suggestion......Case of Cold Beer to the problem solver
Old Aug 22, 2010 | 03:49 PM
TPI BOY's Avatar
TPI BOY
[QUOTE=Yesterdayscorn;1575046921]
Old Aug 23, 2010 | 11:19 AM
Yesterdayscorn
7th Gear
Thanks.....I think that is my next step. Do you know if I would have to take the car in (Tow) or can I just take the PROM out and to the shop?
Appreciate the input.
Mike
Old Aug 23, 2010 | 01:32 PM
TPI BOY's Avatar
TPI BOY
Does the shop have a new prom?
Old Aug 23, 2010 | 02:02 PM
Yesterdayscorn
7th Gear
Not sure, I have to call.....mech said the one that is in there is not original and the number wont cross over to anything. Was changed out many years before I got the car.
Old Aug 23, 2010 | 03:30 PM
TPI BOY's Avatar
TPI BOY
Give them a call, does your car have any mods
to it or is it stock
Old Aug 27, 2010 | 12:06 PM
SunCr's Avatar
SunCr
Out of production and numbered/burned according to equipment - tranny and rear-end ratio. Maybe if you post your Year, someone will have the number you need and then you can call the Vette boneyards.
Old Aug 29, 2010 | 04:02 PM
TPI BOY's Avatar
TPI BOY
Did you get it fixed yet?
To Code 41 Cylinder select error...please help
