Codes 43 and 64?!
Old Aug 18, 2010 | 12:27 PM
cicch95's Avatar
cicch95
Finalist 2020 C4 of the Year - Unmodified
Default Codes 43 and 64?!
Hi everyone. My car is giving me problems. When it is idleing in the garage it sounds / runs fine. When I drive it, it sounds very loud and horrible. It is backfiring like crazy. I jumped the codes and got a 43 and a 64. So, these tell me that I had a problem with either the knock sensor and/or the O2 sensor. Right?
Could this cause the problem I am describing? Where do I start?
Help!!
Thanks,
-Rick
Old Aug 18, 2010 | 12:53 PM
GKK's Avatar
GKK
Yes, code #43 is the Knock Sensor Circuit and code #64 is Bank 2 RF Heated Oxygen Sensor #1 Circuit Lean.
I would start there.
Old Aug 18, 2010 | 01:46 PM
cicch95's Avatar
cicch95
So, by start there you mean replace the knock sensor and the O2 sensor?! (pardon the ignorance here!)
Old Aug 18, 2010 | 01:48 PM
sailorsteve's Avatar
sailorsteve
You need to run the diagnostic test on those sensors as spelled out in the FSM.
Old Aug 18, 2010 | 02:20 PM
cicch95's Avatar
cicch95
Hmmmm.........
Sent PM.
Old Aug 19, 2010 | 10:23 AM
sailorsteve
Originally Posted by cicch95
Hmmmm.........
Sent PM.
Responded to your PM.
Old Feb 17, 2016 | 06:58 PM
larry_c4's Avatar
larry_c4
Hey, did you ever figure out what the problem was? I'm having the same problem.
Old Feb 17, 2016 | 08:50 PM
antfarmer2's Avatar
antfarmer2
Same problem same answer change the front two o2 sensors. It is setting off the knocks I would change the knocks while under there more for a proper flush than anything else.
Old Feb 18, 2016 | 08:00 AM
sailorsteve
Throwing parts at a problem without diagnosis is like playing the lottery. You may get lucky, but you also may just wind up a little poorer.
I have the '92 FSM and can post pages from it if helpful.
Old Feb 18, 2016 | 08:32 AM
antfarmer2's Avatar
antfarmer2
but normal maintenance is not throwing parts at it
Old Feb 18, 2016 | 08:49 AM
WVZR-1's Avatar
WVZR-1
This says that poster "larry_c4" needs to do some diagnostics and maybe explain further his circumstances.
You're "assuming" but your post count is +1
You've "assumed" again to CYA but the post count is + another 1. How did you determine your thoughts were "normal maintenance"?
A genuine offer of assistance
Old Feb 18, 2016 | 08:51 AM
sailorsteve
See my "headlight gremlin" thread from last year to understand why good diagnosis is rule #1.
Old Feb 18, 2016 | 11:01 AM
antfarmer2's Avatar
antfarmer2
This is a forum that folks come for help and opinions this is mine do what you want and let us know. I always want to know what the fix was always learning.
If you don't agree with it then put yours in to help. Bitching about it is fine if it helps you in some way.
Sure getting proper diagnosis is always best and reading the book will do this.
I chose to try to help sometimes I get lucky. Some just tell you to read the book thier choice.
Some do not have the tools or knowledge.
Some do not want to pay hundreds of dollars to have it done.
I could not care less about thread count. Are there prizes that I don't know about? LMAO
Old Feb 18, 2016 | 11:23 AM
antfarmer2's Avatar
antfarmer2
Nice commentary but no helpful information to help OP. You seem to have a vast collection of books. Use them to help would be great. ing around to bitch about my suggestions do not help the OP. I use my years of working on cars and thirty plus years building them in the factory to try to help. I cannot see from here so just guessing. If you like following me around and bitching feel free if it gives you enjoyment.
Old Feb 18, 2016 | 11:35 AM
larry_c4's Avatar
larry_c4
I used the paper clip to pull codes via the digital dash and now got 3 codes, H42, H43, H64. I cleared them all out of the ecm via dash. I have been driving it and it seemed to be running good for the first two days (after clearing the codes) But...today the SES light came on and I immediately checked for codes. Just as I thought, a H64 (Oxygen sensor) and no other codes present. This tells me that the oxygen sensor(s) are Causing the knock sensor code (43) over time. I think by replacing the O2 sensor, the knock codes won't re-appear.
Old Feb 18, 2016 | 11:47 AM
antfarmer2's Avatar
antfarmer2
Does yours have two? If so replace both to match should run much better.
Old Feb 18, 2016 | 11:49 AM
antfarmer2's Avatar
antfarmer2
To Codes 43 and 64?!
Old Feb 18, 2016 | 12:11 PM
Black LS2's Avatar
Black LS2
Both perspectives are appreciated! This forum is great because multiple people add their input!
Old Feb 18, 2016 | 12:18 PM
larry_c4's Avatar
larry_c4
I am pretty sure the LT1 has two sensors. Even though its 'Right o2 lean' I think I am going to replace them both.
Old Feb 18, 2016 | 12:33 PM
antfarmer2's Avatar
antfarmer2
I think your right on yours mine has three but they were setting up for ob2 in 94. Get the o2 socket from Oriely's for $20 deposit use the short one pass side is a bit harder.
I did the knocks and fuel filter since I was under there but that's just me.
