Still willn't Start
Old Aug 21, 2010 | 12:05 AM
Marv02's Avatar
Marv02
Default Still willn't Start
Still willn't start I have 40lb's of fuel pessure.
Have pulse at injectors Plugs are firing they are getting Black so its getting fuel.
I have white spark but is this enough for it to run I ben told it need to be Blue.
Do you think it could be a bad or going bad Ignition control Mod.
I move the distrbetor every way 1 and 2 teeth.
I not 180 Out.
I can feel the pipe are warm I can hear wanting to start once in a while you can hear it cacth trying to run.
I put the motor on TDC both Vavles are closed when putting the motror on TDC it is on compression.
Old Aug 21, 2010 | 01:49 AM
jfb's Avatar
jfb
Plugs should not be black. This is a sign of excessively rich mixture. Does your fuel pressure hold up for at least 30 minutes with the ignition off? If not you may have leaky injector/s or injector/s stuck open causing too rich mixture to start.
Spark should be at least 1/2" long. Bring a grounded wire near the boot of an unplugged spark plug wire during cranking. Badly carboned spark plugs can conduct and then will not spark. Did you measure cylinder compression?
Old Aug 21, 2010 | 02:07 AM
Marv02's Avatar
Marv02
Yes Thers 1/2 White Spark out plug wires.
There New FIC injectors 24# Bosch type 3.
Yes It's holding Fuel Pressure.
Try to clean the pulgs and try again.
I picked up a good used MAF just to makes sure the car was not going to full rich condition.Could it be a bad IAC I did clean the Thottle body when rebuilding the motor with some carb cleaner.
Once before When I tryed to tune the car up I disconected the IAC the car would not start then.
Old Aug 21, 2010 | 04:16 AM
powerpigz-51's Avatar
powerpigz-51
Any codes? Try pulling fuses INJ1 and INJ2 out of fuse box and try to start with starting fluid. This will at least eliminate fueling problems as a cause, if still a no start.
Old Aug 21, 2010 | 05:17 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
Suggest connecting a timing light while your cranking and see whether you're near where you should be.
Old Aug 21, 2010 | 07:58 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
My thoughts too, sounds like the timing is retarded. Try turning the distributor counter-clockwise a tiny bit, 1/2 inch or so. If it sounds more like it wants to start then move it another 1/2 inch. Once it fires then you can set the timing. If you have the est wire unplugged, plug it back in until you get it running then you can unplug it again to set timing properly.
Old Aug 21, 2010 | 12:39 PM
Marv02's Avatar
Marv02
I am getting intermediate pulse at the Injector connections.
Is the ECM Fried ????.
Sometimes the plug are wet others they are dry.
I don’t get it. What am I doing wrong.
Old Aug 21, 2010 | 02:10 PM
powerpigz-51
If you try this and it still doesn't start, you can stop worrying about the wet and dry plug situation and concentrate on getting a properly timed spark. You might look and see if the plug wires were placed in the firing order in the right direction on the distributor cap. You need three things for your engine to run, a proper fuel mixture, a properly timed spark, and compression. You have spark (you say you have tried everything timing wise) you are unsure of the fueling situation (easily checked) and I assume you have compression (also easily checked).
To Still willn't Start
