Newbie Alert - need info
Old Mar 27, 2002 | 09:53 PM
Hammer's Avatar
Hammer
Default Newbie Alert - need info
What is involved in tuning my '92. From the little I know, I need to have chips "burned". Is this something that a DIYer can do?
Thanks.
Jim
Old Mar 28, 2002 | 02:42 AM
hotwilzz's Avatar
hotwilzz
Default Re: Newbie Alert - need info (Hammer)
check out the first post in this section. it's new to me as well but this gives you a ton of the basics. it also created many more ?'s for me, but at that point the ?'s are more focused
good luck david
Old Mar 28, 2002 | 03:05 PM
Goody's Avatar
Goody
I'm in the process of gathering the equipment to do the chip burning for my 93 now. I have the AKM Cable adapter to plug into the ALDL port and into my laptop (bought used) and a copy of TTS's Datamaster software so I can see what the car is doing.
I also just ordered an adapter from Craig Moates to make programming easier. A ZIF socket and doing without the memcal. Read up on that to get the idea. I don't need a UV eraser since I will be using the AT29C256 flashable EEPROM chips instead of the normal 27C256 that requires the erasing before using.
My plan is to get the pocket programmer to do the updating with and Tunercat for the editing. Sounds like a lot of stuff, but the only true way of optimizing my car for my needs and mods.
Read the FAQ a few times. I have and check into this board as well as the thirdgen board for info and help from the others. :seeya
To Newbie Alert - need info
