4+3 Overdrive Cutout Switch
I've heard there's a way to install a cutout switch on the OD so I can turn it on and off with a toggle switch. Any help with how to do this is appreciated!
Maurice
With mine off, no matter how hard I drive it or hit cruise, the OD will not engage until I turn it on.
O/d will automatically engage once correct programmed conditions are met; engine temp / TPS / road speed/etc
Already have one; need to hit O/d switch before driving off to disable
All you are doing is bypassing the 1st gear lockout switch.
O/d relay control still comes from the ECM.
See '84 O/d diagram below
No feedback to ECM from O/d for check engine light.
O/d light on dash only shows ECM is "trying " to turn O/d on; does not indicate that it is actually engaged
Switch takes out power to the O/d regardless of what the ECM is doing
Join blue to pink / blk at relay, bypassing relay.
Switch is now only thing controlling O/d giving full manual control ( with 1st gear lockout unless also you bypass the 1st gear switch as noted above).
Light will still come on when ECM tries operating the relay but as the relay is bypassed , nothing will happen
On the '84 there is a rocker switch on the console. If that rocker switch is in the off position the O/D will not come on automatically when you start the car or by default.
What this sounds like is the OP does not know, maybe due to the silk screen being rubbed off the console...or whatever.....The OP does not understand what that switch does.
Also, the switch itself may be defective and the O/D is stuck in the ON the position. Therefore the OP does not believe that the rocker switch does anything.
I leave mine off and use it as a regular 4 speed around town. When I go on the highway, I get into 4th and then turn on the OD.
The OD even kicks off and then back on if you punch it to pass etc.
It works great for me!
