sir system 1990
Old Aug 23, 2010 | 02:00 PM
VETT90's Avatar
VETT90
Cruising
Default sir system 1990
Is there a simple way to check out system to correct ?? my infl rest light stays on-
Old Aug 23, 2010 | 05:34 PM
Kleantouch's Avatar
Kleantouch
Mine came on, stayed on- looked at the relays near the battery, thought about cleaning the grounds, etc- instead bought a $20 switch from MidAmerica, hooke it to the OBD connector, pushed the sw like the directions said, and it hasn't come back on. Good luck.
Old Aug 23, 2010 | 06:07 PM
vette079's Avatar
vette079
http://www.zr1netregistry.com/Old_Proj/old_proj7.htm
http://forums.corvetteforum.com/c4-t...ir-system.html
Old Aug 31, 2010 | 11:17 AM
VETT90's Avatar
VETT90
Cruising
can you better explain this??
Old Aug 31, 2010 | 11:19 AM
VETT90's Avatar
VETT90
Cruising
Can you better explain??
Old Aug 31, 2010 | 12:54 PM
Bad Karma's Avatar
Bad Karma
Also:
https://www.corvetteforum.com/c4/use...-corvettes.php
To sir system 1990
