A/C blowing defroster/floor only
I have a 93 6-speed with the automatic HVAC. My A/C will only blow out of the defroster and floor vents no matter what position the controls are set in (The green lights above the buttons turn on when the buttons are pushed). Every few days it will start to blow out of the dash vents for awhile, but it always goes back. Still blows cold though. Texas daily driver, 100k miles.
I'm thinking it is a vacuum issue. The check valve at the passenger side intake manifold works like it is supposed to, and I when i pulled it off i heard hissing, so the supply line to the HVAC vent controller isn't leaking. Just to check, I also hooked up a vacuum tester to this line, and it held vacuum.
I took off the cover under the steering column and contorted myself under there
to take a look at the controller box where the vacuum lines go into it. I can't see anything wrong, but I think I need to take this thing out and inspect it; maybe the solenoids are not working, although i could hear clicking from the box each time I would change the A/C vent setting. How do I get that stupid push-on nut off the vacuum line manifold so I can take the box out, or just to check for vacuum at the manifold?
Any other ideas? I really don't want to take the dash apart again (been there for heater core - what a pain)
Thanks,
Josh
I finally got that controller box out of there and guess what... it had those rubber nipples that were collapsed (I thought only 96's had this problem...) I cut off the collapsed thin part and re-assembled and everything works perfectly.
I used the original hard plastic nipples out of my failed one (90) and put it in the replacement (96) that had the rubber nipples and it worked great.
I ended up using the solution from "bvsmith" shown in "link 1". I recommend this over cutting down the connectors because those holes are still awfully small and may choke down the vacuum pressure too much. With new vacuum line you don't have to worry about that funky connector making a vacuum leak either. Plus I busted mine trying to get it apart because of the "push on nut" holding the 2 connectors together.
With the stupid connectors from GM now gone and reconnected with new vacuum line, it now works in about 1 second when switching from floor to vent or to defrost. Highly recommended mod for anyone with this problem. Took me about 5 or so hours total, but well worth it.
