what wrench or socket to use
Old Aug 23, 2010 | 06:09 PM
joesgulfstream's Avatar
joesgulfstream
Default what wrench or socket to use
I want to remove the front right 02 sensor on my 95 what kind of 7/8'' socket or wrench can I use . I cant use a regular open end
Old Aug 23, 2010 | 06:55 PM
WW7's Avatar
WW7
I used what looks like the open end head of a regular wrench but it has a hole in it to use a 3/8" extention to turn it with a ratchet..I also have a ratchet wrench with a swivel head that would probably work, or a stubby wrench with a flex head might work....WW
Here is a link to the socket wrench set I used, its called a (crowfoot wrench).. WW
http://www.google.com/products/catal...d=0CDsQ8wIwAg#
http://www.amazon.com/s/?ie=UTF8&key...l_3c10upllfo_b
Old Aug 23, 2010 | 07:09 PM
F22's Avatar
F22
Originally Posted by WW7
I used what looks like the open end head of a regular wrench but it has a square hole in it to use a 3/8" extention to turn it with a ratchet
Good one! I believe they call it a crows foot wrench. On the 87', I had to buy an 'Offset' wrench and that worked really well. Unplug the sensor and run the wire through the closed box end and it worked great. A deep socket with a swivel might work too, from underneath or on top, depending on what angle you're looking at.
Old Aug 23, 2010 | 07:12 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I just disconnect the wire and slide the box wrench over it.
Old Aug 23, 2010 | 07:13 PM
ch@0s's Avatar
ch@0s
You need this $4
http://www.harborfreight.com/3-8-eig...ket-95045.html
Aardwolf's Avatar
Aardwolf
Same here, works well.
Old Aug 23, 2010 | 07:39 PM
Al Borman's Avatar
Al Borman
7/8" stubby is what I use. Make sure you disconnect the battery, as it is very easy to "touch" the starter Bat terminal with the end of the stubby by accident.... ask me how I know !!!!
Harbor freight or Sears carries the stubs !!
Old Aug 23, 2010 | 08:11 PM
joesgulfstream
Originally Posted by ch@0s
I think I will give this a try, I thing I will have room.
Old Aug 24, 2010 | 08:13 AM
onedef92's Avatar
onedef92
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I used this one. Cost $9.99 at Harbor Freight.
Old Aug 24, 2010 | 08:30 AM
onedef92's Avatar
onedef92
I used one similar to that one this past weekend when I swapped out the 02 sensor of my wife's DD.
To what wrench or socket to use
