85vette power window issue
Old Aug 23, 2010 | 08:08 PM
acinco51's Avatar
acinco51
Default 85vette power window issue
my driverside window will only go half way up. It goes down from that point, and when i try to close it, it stops half way. i can here the motor working but will not move do you think it is the plastic ribbon inside? i thought maybe the gears had worn down.
Old Aug 24, 2010 | 12:58 AM
C4boy's Avatar
C4boy
Sounds like the ribbon may be cracked, but you'll have to pull the door panel and dig in there to find out for sure. I might have a ribbon you can have if needed.
Old Aug 24, 2010 | 05:42 AM
acinco51's Avatar
acinco51
thanks c4boy for the offer I thought it was the ribbon and already ordered one. again thanks for the offer.
To 85vette power window issue
