OPTI vacume line check valve?
Old Aug 23, 2010 | 08:28 PM
C4vettrn's Avatar
C4vettrn
Default OPTI vacume line check valve?
I am routing my vac lines for new vented opti. From what I understand the intake line attached to (TB intake tubing) is just an opening for clean air to be drawn through the opti by the vacume of the intake manifold vacum line. Why the check valve? And doesn't this all just create a major vacume leake? I assume the check valve is placed so air flows toward the intake manifold and checks from going back towards the opti? I guess I just don't understand the check valve reasoning and how pulling vacume through an open line doesn't bleed off major vacume?
Old Aug 24, 2010 | 01:07 PM
JAKE's Avatar
JAKE
Let's ALWAYS start off a new thread by correctly identifying the engine we're deailing with. Too many times guys don't update their avatar or signature, etc., which leads responders to think it's an engine it "ain't"
It's a sealed system. Since the source of the air feeding the vented Opti is after the MAF, it's already been measured by the MAF. I see it as being no different as the other vacuum sources (solenoids, FPR, etc.) on the intake manifold - air that's already been measured by the MAF.
Now if the source of air to the Opti was UPSTREAM of the MAF, then that would be UNMEASURED air and to me would be the same as a vacuum leak.
Just my take on this.
Jake
Old Aug 25, 2010 | 07:53 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Jake
Emminently logical there, Jake.
Old Aug 25, 2010 | 11:42 AM
surfer93's Avatar
surfer93
Since I did not want to poke a hole in my bellows, I got a air filter for vacuum hoses and used that.
I got it at the Zone parts store, it is a filter with a nipple on the end for the vacuum hose.
Old Aug 26, 2010 | 12:46 AM
shadowman1's Avatar
shadowman1
Jake
His car is a 1992. Does not have a MAF. It's not a vacuum leak as you are just moving air thru the distributor cap and back into the manifold. It is a very small amount of air.
Old Aug 26, 2010 | 03:16 PM
JAKE's Avatar
JAKE
Confusion reigns surpreme. I saw no mention in his post that the car he was working on is a 92. Unless I'm confused even more, the vented Opti engines were all MAF engines. (Where'd you find out his engine is a 92 by the way?)
To OP: Are you modifying a NON-VENTED OPTI to become a VENTED OPTI or installing a VENTED OPTI in place of a NON-VENTED ONE?
You have a Speed Density system, not MAF, right?
If that's the case, what are you using as the vacuum source and where are you returning the vacuum? TB as the source and manifold as the return location - Vice-Versa?
Just trying to figure out what's going on.
Jake
Old Aug 26, 2010 | 08:18 PM
Al Borman's Avatar
Al Borman
I don't get it ? The intake is used as a vacumm source for all kinds of stuff !! AC/defrost/vent actuator, EGR (where applicable), cruise control, vacumm holding tank, etc. etc., and they use check valves...and there is no return air back to the intake to "zero out" this so called vacumm leak.....
So why would anyone consider the Opti vent scheme to be a source of perceived vacumm leak ?
Since when does a vacumm source need a return ??
Old Aug 26, 2010 | 10:57 PM
shadowman1's Avatar
shadowman1
I clicked on his pic and there in his info it says his car is a 92.
Here is the vent upgrade I did on my opti last month.
http://www.corvettefever.com/howto/16758/index.html
The vent hose kit part # is 12555323
http://www.gmpartsdirect.com/results...umber=12555323
Old Aug 26, 2010 | 11:39 PM
shadowman1's Avatar
shadowman1
I don't know why he thinks it's a vacuum leak. The fresh air comes from the intake duct, goes to the distributor cap and then is pulled into the side of the intake manifold wth engine vacuum. No leak in system. See my above post for a how to on 92 thru 94 systems. It's a very small amount of air and will not effect performance.
Old Aug 27, 2010 | 03:53 PM
JAKE's Avatar
JAKE
Thanks for that.
I've got a mag around here somewhere showing how to mod a NO-Vented Opti into a Vented version. Would take me a while to track it down because I'd have to go through all 100+ lbs of mags to find, but I will if REALLY necessary.
Jake
Old Aug 27, 2010 | 03:59 PM
JAKE's Avatar
JAKE
When it comes to MAP engines, for me, all bets are off. Never having dealt with MAP engines I don't know when or how it detects/measures in-coming air. So I'll leave it to you guys to sort this out.
Like "Dirty Harry" said "Man's got to know his limitations". LOL
Jake
Old Aug 27, 2010 | 11:34 PM
shadowman1's Avatar
shadowman1
Jake
That's a great idea. He sure could have been working on another year model than the one listed under his info.
True also is that MAP cars are harder to diagnose mostly because of the lack of data stream compared to OBD II engines.
PS. On the opti upgrade I had to remove the P/S pump pulley to run my vacuum lines away from the belt and to get access to the lower left water pump bolt. It doesn't mention that in the article I linked to.
To OPTI vacume line check valve?
