Clutch wear
Old Aug 24, 2010 | 08:42 AM
Don in VT's Avatar
Don in VT
Default Clutch wear
Hi All,
Got a real quick question. When a clutch is at the end of its usefull life will the clutch engage at a point right off the carpet or right at the top of the pedal travel?
Thanks,
Don :
lahttp://images.ibsrv.net/ibsrv/res/src:forums.corvetteforum.com/get/images/smilies/patriot.gifg:
Old Aug 24, 2010 | 09:27 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Pedal let out, or travel, is not a direct indication of clutch wear. The pedal in our Corvettes tend to engage in a high position. Mine only has about 5K on it and it does that.
Old Aug 24, 2010 | 09:57 AM
thedudeman321's Avatar
thedudeman321
Usually it will engage higher when wearing down, but like he said, pedal travel (in vehicles with hydraulic clutches) is NOT a direct indication of wear. It will slip when it really needs to be replaced.
My 92 engages very high. Hydraulics are good, no chatter, clutch doesn't slip at all, not even a tiny bit.
Your mileage may vary.
Old Aug 24, 2010 | 12:11 PM
Don in VT's Avatar
Don in VT
Default Clutch wear
I should have included in the post that all the clutch hydralics are new, properly installed and the system properly bled. The clutch arm bushing on the master cylinder is new as well. The clutch engages just off the carpet (aprox 1/2"). Maybe this will help with the question.
Thanks again
Don
Old Aug 24, 2010 | 12:55 PM
BADDUCK's Avatar
BADDUCK
Same answer although most don't engage with the pedal that low.
Old Aug 25, 2010 | 01:08 AM
856SPEED's Avatar
856SPEED
Hmm...when my slave cylinder shot craps (was leaking fluid badly) it was engaging right off the floor, then eventually there was no clutch at all.....after I had the hydraulics replaced (new slave cylinder) the clutch engages near the top of the travel.......
Old Aug 25, 2010 | 10:24 PM
thedudeman321
Sounds typical to me
To Clutch wear
