How do I trouble shoot this?
Second step, if you've access to a laptop, is to get a free copy of TTS Datamaster and the OBD (on-board diagnostics) connector for your year Vette. The software will track sensor readings, DTC's, etc for (I think) 30 minutes per recording session. You get 20 free sessions before you have to cough up a $100 license fee, after that it's unlimited recording.
Dunno about after that.... I'm still in the recording/analyzing stage with a hot engine stumble on my 94 LT1.
Good luck!
A scan tool or PC cable and software can be useful as fuzzydawg mentioned to view live sensor data, reading codes is only one function of a decent scan tool. Other tools that will be very helpful are a digital volt ohm meter and fuel pressure gauge.
Resist the urge to buy the very cheapest ones, just as the genuine factory service manual is worth much more than the Haynes comic book. For those who are not familiar with using a DVOM, purchasing one that has autorange capability can be very helpful since you do not need to choose the correct range to get an accurate reading and they only cost slightly more than the most basic tools. Fuel pressure gauges are no different, the cheapest ones invariably have a very short hose, spend more to get one with a hose long enough that you can tape it to the windshield while driving so you can observe what happens under load.
A decent inexpensive substitute for the FSM is an annual subscription to ALLDATA, for less that $30 you can have access to most of the same information and some that is not included in the FSM. Another benefit is that with a credit card you can sign up and have virtually instant access instead of waiting for a manual to be delivered.
One last suggestion is to simply do a very thorough visual inspection with emphasis on vacuum hoses and secondary ignition wires, do that part at night to spot arcing wires that can cause issues such as you describe. Good luck.
If $$$ are an obstacle, your can visit shbox.com and GrumpysPerformance.com for their trouble-shooting posts on many of our most common issues.
Jake
Haynes comic book- Thats funny
http://www.ttspowersystems.com/DataM...ownloads2.html
For your 92, you need DM35xDA.
Cables (including OBD-I) are here:
http://www.aldlcable.com/
Good luck!
http://www.amazon.com/Actron-CP7838-.../dp/B0009XQUKC
http://www.amazon.com/Equus-3320-Aut.../dp/B000EVYGZA
Once again I must say the FSM has a very helpful tutorial at the beginning of the electrical section that does a decent job of describing basic operation of volt/ohmmeters and other electrical test tools.
-my guess(es):
your symptoms sound like 'lean backfire'...today's 'blended' gas/alcohol mix does not match the original ecm air/fuel/timing tables, misfires in some cars (if possible, find a vendor that is not selling corrupted gas and see if problem vanishes)...spark plugs of wrong type/excess gap/multi-electrode/etc may tend to misfire under load , old/bad plug wires same (what's in your walker ?)...a CTS that is 'off calibration' (many are) will cause the ecm to skew air/fuel ratio (unplug elec connector and check CTS ohms at 'engine cold' and also at operating temp with a DVOM or scanner, compare to SM values)
Fuel delivery is a function of the Coolant Temp Signal so that's the one piece of data I'd want to see with my scanner - particularly since this is a "hot" problem. Starting with a cold engine, it should read ambient and then rise to the thermostat; drop a degree or two when it opens and then rise to the threshold for coolant fan operation. Otherwise, the more logical piece would be a fuel injector or injectors so check resistance across the injector coils cold and hot. They should all be 15 to 17 ohms.
If they're ok, this is an early Opti so there's a high probability that yours is toast and depending on mileage, maybe never replaced - check recalls against your VIN.
If you still can't find it, you can try isolating it to a cylinder, but with an opti it's tough without a tool to kill each cylinder - pulling a plug usually does nothing as the ECM will compensate and since this is a load problem doing it in your driveway probably won't tell you anything. As an alternative, check compression or if high miles, measure valve lift; look for a broken valve spring.
I like using a scanner and or a laptop with software, as it is easier and faster to see all the inputs from sensors etc. I'm not convinced you need to change the wires etc., however checking them for cracks, burnt etc., and pulling the plugs (seeing how they look) would also be routine.
As to buying which product first...ultimately with these cars you will probably end up with both.
Ha Ha! I trouble shot how to get an avatar and I was successful!
