-92 LT1 Tacho output question
Old Aug 24, 2010 | 04:51 PM
Svante's Avatar
Svante
Default -92 LT1 Tacho output question
Hi. Does anyone know wich one of the wires from the original ECU that is the Tacho output for the dash? I have installed an aftermarket Ecu but cant find the wire on my crappy wiring diagram. If it´s possible i also like to know what signal it uses so i can calibrate it for a proper operation.
Thanks.
/Johan.
Old Aug 24, 2010 | 06:27 PM
rodj's Avatar
rodj
Originally Posted by Svante
Hi. Does anyone know wich one of the wires from the original ECU that is the Tacho output for the dash? .
Tacho feed doesn't come from ECM.
White wire out of tach filter ( blk plastic block wired into harness near ICM ) goes direct to tacho
Wire # 121 white to IP ( Instrument panel )
See
http://www.lt1swap.com/pictures/100_1795.jpg
Good wiring schematics here
http://www.lt1swap.com/1993_y_body_h...schematics.htm
Old Aug 25, 2010 | 01:13 AM
Svante's Avatar
Svante
See
Allright. Thank you! I´ll have a look and see if it works.
/Svante.
To -92 LT1 Tacho output question
