My Max AC quit working
Old Aug 26, 2010 | 01:41 AM
1allspub's Avatar
1allspub
Default My Max AC quit working
As the title says... my max AC quit working, ie, when I put it on max nothing changes (like it used to). It's just the same as normal AC. It still cools, but the volume of air doesn't kick up like before.
My car used to just about freeze me out when the max AC was working correctly... what gives? Anyone?
Thanks in advance!
(btw... it's an 88)
Old Aug 26, 2010 | 04:03 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Probably your high fan relay, it's located directly under the fan motor.
Old Aug 27, 2010 | 09:05 AM
1allspub's Avatar
1allspub
Okay, thanks I'll check it out. Thought maybe it was a vacuum problem or something (doesn't the venting system operate on vacuum?) Hope it's just the relay, that sounds like an easy fix.
Old Aug 27, 2010 | 10:23 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
It's a C4. There is no easy fix.
To My Max AC quit working
