Best shorty headers
Old Aug 26, 2010 | 11:12 AM
89vette's Avatar
89vette
Default Best shorty headers
Well I've put on 23 miles on my 89 since this time last year. I'm thinking I'm going to take off the TPIS long tubes and install a set of shorty headers and cats from an LT1 car since I am running the Corsa LT1 style exhaust now. I have the long tubes with bullet cats on the end currently and custom pipes that fit to the Corsa pipes. I get a lot of under hood heat to the point where it ruined the paint on the hood and melted some wire shielding. I'm always afraid something is going to catch on fire.
Who makes a good shorty header? I want a good quality one.
Old Aug 26, 2010 | 11:33 AM
cv67's Avatar
cv67
St. Jude Donor '05
Quality? Dougs makes a real nice LT1 shorty...get the smog tubes if you use them and adapt them to your L98 nice setup. Id never go back to another brand again after using these I was impressed.
Wasnt thrilled with the Hookers (not bad though), the BBK shorty didnt fit it hit the ac box and needed imo too much to work but plenty of guys use both and like them.
Old Aug 26, 2010 | 12:45 PM
89vette's Avatar
89vette
Thank you for the reply. They look like quality pieces. Does anyone make an off road pipe to replace the factory cats on an LT1 style system?
Old Aug 26, 2010 | 01:28 PM
Strick's Avatar
Strick
I'm running a set of Hooker shorties with the Jett hot Sterling ceramic coating. They still look new after 6 years or so. Fit was perfect, just had to shorten the AIR pipe on my 92 LT1. They sound great thru my modified stock exhaust with muffler e-lims. I bought them directly from JettHot. Compared to the old cast manifolds, the heat was really reduced under the hood. You might want to check your timing if the heat is that hot under the hood.
Old Aug 26, 2010 | 01:53 PM
89vette's Avatar
89vette
My timing is OK. It's just a big engine and the bullet cats probably hold alot of heat I assume.
Old Aug 26, 2010 | 04:51 PM
mcm95403's Avatar
mcm95403
I wouldn't assume that the cats are the problem.
Pick up a hand-held infra red thermometer and see what the temps are. Sounds like you may be running too lean, or the cam could also be off a tooth (or the valves could be adjusted incorrectly) causing raw fuel to pass through the chamber and burn in the headers.
The amount of heat you're describing is not normal and I seriously doubt it would change just because you change the type of header.
Old Aug 27, 2010 | 11:04 AM
89vette's Avatar
89vette
I can do that. What should the temps be? I do my own scanning and tuning and its not lean. It was hot under the hood even before I had the solid cam in. I've had long tubes on this car for the last 10 years or so.
Old Aug 27, 2010 | 10:39 PM
mcm95403's Avatar
mcm95403
Not sure what the temps should be. Maybe someone with non-stock headers could chime in on that.
Old Sep 2, 2010 | 04:44 AM
Rag Top's Avatar
Rag Top
I am running SLP shorties, and like them. I would say SLP, Lingenfelter (if you can find them), and JBA.
I would see if your heat issue might be something other than the long tubes before swapping them out though.
Old Sep 2, 2010 | 05:55 PM
C4vettrn's Avatar
C4vettrn
SLP and LPE are no longer avalable, JBA thinks there's are made of GOLD, great quality and one of the only stainless shorties. Doug's are a quality piece and have spacers for the motor braces and longer primaries with 16 guage steel, hooker uses 18 on most of there headers.
Old Sep 2, 2010 | 06:56 PM
HlhnEast's Avatar
HlhnEast
I cant imagine the LTH's generating that much heat, enough to bubble paint or melt wiring without some other problems mentioned above. Although it will be a PITA at this point, try some header wrap. Its seriously tough with the headers installed Since you would be taking them off and installing another set it would be no more work just to take em off to wrap them. The wrap should reduce the heat considerably. It would be a lot cheaper than buying another set of headers. The wrap does have some issues with moisture and if you got salt in them it would be a killer.
Old Sep 3, 2010 | 09:47 AM
89vette's Avatar
89vette
It's not that bad. The paint didn't bubble it is just dulled on the hood but the car is 20+ years old. The wires really didn't melt, it was more the the plastic casing that the wires are in.
I'm getting the clutch slave cylinder replaced right now and the guy can't get it bled right (I didn't feel like doing it myself). I test drove it yesterday and just decided I'm done putting money in it. I've lost the desire to turn wrenches like I used to. I'm kind of sorry I went with the solid cam because its just a little too much to enjoy the car on the street. It lost most of its low speed smoothness. Putting the Super Ram back on in lieu of the single plane Jeb Burnett intake might fix some of that but again I have no desire.
I think it might be time to sell it and get something newer.
Old Sep 4, 2010 | 12:45 PM
856SPEED's Avatar
856SPEED
I was going to say that I have been running TPIS long tube headers (ceramic coating) for some time w/o excessive underhead temps....going to shorties is not an upgrade...just MHO....but sounds like you are ready to move on to something else anyway....take care
Old Sep 5, 2010 | 02:27 AM
JAKE's Avatar
JAKE
I ran TPIS long tubes on a 415 CID engine I installed in my 86 Vette with a PCMFORLESS PROM tune and didn't have the under-hood heating problems you've experienced. All I did was wrap the driver's side collector and rearward tubes as a precaution against heating the oil filter and install a $7.00 IIRC solenoid heat shield on the starter solenoid (AutoZone).
Never had a hood paint or wiring issue though. So I'm thinking timing and/or fuel, even though you're convinced yours are right.
I do recall that while setting the initial timing a taking my time about it, the headers did turn a beautiful orange/red until I locked down the distributor and plugged in the by-pass connector/cleared the code. Once the ECM took over the timing the pretty color went away and all returned to normal.
Jake
To Best shorty headers
