Replace radiator as preventative maintenance? Just rebuilt trans.
Old Aug 26, 2010 | 04:11 PM
Ape0r's Avatar
Ape0r
Default Replace radiator as preventative maintenance? Just rebuilt trans.
I just spent 3k on having the transmission in my '92 C4 rebuilt. As they went to test drive it after installing the rebuilt trans, one of the upper radiator hoses literally burst.
Naturally, I am going to replace all of the radiator hoses - but this has me wondering. After spending all that money on the transmission, it would be a shame if an internal radiator leak ruined it.
Have folks seen problems on these cars with internal radiator leaks on these cars? How worried should I be? $250 for a radiator seems like cheap insurance against another 3k rebuilt!
Old Aug 26, 2010 | 04:44 PM
cv67's Avatar
cv67
St. Jude Donor '05
Heck if its the 14 yr old original and spending 250 doesnt bother you I would. Worth it in the long run and peace of mind.
Used to replace both fan relays and keep the old ones around "in case". Relays are cheap less than 20
Old Aug 26, 2010 | 06:13 PM
bwiencek's Avatar
bwiencek
How well the car has been maintained would make my decision - if it were neglected in it's past life then I'd take a good look at it and probably end up doing it, but if it was maintained and the coolant kept changed regularly (so the corrosion inhibitors were at the proper levels to prevent deterioration of the metal components) and an inspection of the radiator showed everything to be clean inside then I would leave it and keep maintaining it as it had been..
If you don't know the history and things have been "going wrong" since you bought it then I'd replace it not knowing how previous owners maintained (or neglected) it.
Old Aug 26, 2010 | 07:18 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
If you do replace the radiator, don't buy the cheapest one you can find. There are some really cheap ones coming from China these days.
Old Aug 26, 2010 | 07:52 PM
1989vette's Avatar
1989vette
Paul, what do you suggest?
Old Aug 26, 2010 | 08:06 PM
SJW's Avatar
SJW
At this price for NOS, I'd say it's a no-brainer:
http://www.corvetterecycling.com/category_s/89.htm
Live well,
SJW
Old Aug 26, 2010 | 11:09 PM
Ape0r's Avatar
Ape0r
Live well,
SJW
Absolutely. Trigger is pulled. Saw them for 212 (ac delco) on rock auto, that seemed cheap to me. For a hundred bucks, I'd be stupid to not change it. Thanks for your replies!
Old Aug 27, 2010 | 07:28 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Live well,
SJW
Wow. Those are some good prices for recycled, O.E.M. parts.
Old Aug 27, 2010 | 04:06 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
I bought one of these from CR in the Spring. It's actually a brand new NOS piece, and fit perfectly. I couldn't have gotten my old one cleaned for that price.
To Replace radiator as preventative maintenance? Just rebuilt trans.
