code H16 on a 94
Check to make sure that the WP weep hole is not leaking coolant on to the Opti.
If your engine runs fine at all conditions, and your WP is healthy, I would clear the H16 error code, and monitor on a weekly basis.
Anyway, it is not unheard of that a brand new Opti will be DOA, or have a life span of the common house fly. When you say "new, dist, cap and rotor", I assume you mean that you bought a complete new Optispark ? What brand Opti did you purchase? Some of those inexpensive fleabay China knock-offs are pure junk.
I would clear the H16 code, then try to restart, and see if H16 re-appears. If it does, my bet would be that your new Opti is toast.
Also, the 2 times that the engine ran, did it run smoothly and for a decent length of time, or did it stumble, puke and cut out quickly ? Just want to make sure that Opti spline was keyed correctly to the camshaft.
Optis differ based on year and so are the trouble-shooting procedures when one has been swapped.
Jake
