HID replacement for FOG-Lights
Old Aug 27, 2010 | 10:16 AM
wro87's Avatar
wro87
Default HID replacement for FOG-Lights
OK gang heres the deal I put in HID replacement bulbs in my 87' well when I put the first one in and tried it out man was that the way to go since we have a black out kit on the front. Well when I got the other one in and tried it out later that night unknowing that when i turned them on and was trying them out I had blown the fuse and lost all my running lights untill I got back to the shop. No big deal i just figured that May have shorted something out. Put a new 10amp fuse in and flipped the switch it popped IMMEDIATELLY. What do you think ? Can I put a little bit bigger fuse (15amp) and not worry? The lights where real simple to plug and play and have checked for shorts and can not find any.
Thanks GANG
wro87
Old Aug 27, 2010 | 10:24 AM
F0RMULA's Avatar
F0RMULA
i had the same thing happen to me a few years ago, but i just took them out. it wasn't worth the potential problems. they DID look cool though for few minutes before they blew everything
Old Aug 27, 2010 | 10:47 AM
krazy1's Avatar
krazy1
When you upgrade the bulbs to 885's you need to go to the 15 amp fuse.
Old Aug 27, 2010 | 01:16 PM
wro87's Avatar
wro87
Thanks I will try that first and see how it goes!!!!
wro87
Old Aug 28, 2010 | 11:00 PM
wro87's Avatar
wro87
Well gang 15amp fuse and it works so far!!!
Thanks gang wro87
Old Aug 29, 2010 | 06:04 AM
armybyrd's Avatar
armybyrd
Any pics?
Old Aug 29, 2010 | 12:41 PM
Calderone's Avatar
Calderone
Hi Wro ! im running HID fogs as far as i know i was the first one to use them like 2 years ago and yes i used a 20A FUSE,but i replace it from time to time because it gets very hot.
Where did you get yours ? i would love to know how to attach them to the twist-lock
housing,i had to make some mods...check my posts !
http://forums.corvetteforum.com/c4-g...own-fuses.html
http://forums.corvetteforum.com/c4-g...tall-them.html
http://forums.corvetteforum.com/c4-g...l-you-how.html
Old Aug 30, 2010 | 12:41 AM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
PLRX has done THE definitive write up complete with pictures on HID fog lights. The search function is your friend.
To HID replacement for FOG-Lights
