I have an 86 pace vette. It has 1989 vette 17 inch wheels. The rubber is Goodyear. The problem is the left front tire. 2 inches from the outer edge the tire is cupping. The right side is fine. I run the tires with 36 psi and check them often. The back tires are fine too. I have replaced the front leaf spring, A-frame bushings,swaybar bushings, had the ball joints checked and a front end alignment all about 25,000 miles ago. Anyone have any answer. Thanks
Hey everyone... thanks for the info. It's been 7 years an 40,000 miles since I changed the shocks.I guess I'll replace the front shocks....Thanks again
