what spark plug gap to set?
Old Aug 28, 2010 | 07:40 PM
mingey's Avatar
mingey
Cruising
Default what spark plug gap to set?
like the title says i have ngk g-power plugs. but the kicker is i am also installing a msd opti(lt1- hopefully opti is a givaway), plug wires and blaster coil... so i am lost as far as setting the gap?
also side note i am replacing the valve cover gaskets oil pan gasket and water pump. also i am useing the old rod and slege hammer method of takeing of the crank pulley. so if any body knows any tricks to the trade to make any of that eaiser feel free to comment thanks again
Old Aug 28, 2010 | 08:05 PM
sailorsteve's Avatar
sailorsteve
Spark plug gap from 92 FSM- 1.27mm/0.035"
Before removing the front pulley, mark the location so you can put it back the same way. The pulley incorporates the harmonic balancer, and there are two wrong ways as well as the right way to put it back on.
Old Aug 28, 2010 | 08:12 PM
STL94LT1's Avatar
STL94LT1
Wrong!! The pulley/dampner will only go back on one way, the ears of the hub are slightly assymetrical.
Old Aug 28, 2010 | 09:08 PM
tblt44's Avatar
tblt44
this is my link to my pulley removal,it took me 3 days to get it off.someone posted a link to a pulley puller for 67 bucks,I think its in this post,buy it save time and trouble.
Then sand the rust off and put anti seize on the hub before reinstall.
http://forums.corvetteforum.com/c4-t...ulley-lt1.html
also if your doing plugs see this post they are a PITA
http://forums.corvetteforum.com/c4-t...es-on-lt1.html
Old Aug 28, 2010 | 09:14 PM
sailorsteve
I stand corrected- what I meant to say was, while the pulley can only be installed one way, you're better off to mark it so you aren't trying to line up the bolts in the wrong holes by putting it in the wrong position. Anyway, I marked mine when I took it off.
Old Aug 29, 2010 | 05:34 PM
JAKE's Avatar
JAKE
LOL
Jake
Old Aug 30, 2010 | 09:06 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Don't forget the anti-seize compound for the new plugs. Did your old wire looms and holders break as you went to remove them? You can order new ones from Mid-America Motorworks (MAM).
To what spark plug gap to set?
