new distributor
Old Aug 30, 2010 | 04:38 AM
maverick1453's Avatar
maverick1453
Default new distributor
i have a 93 corvette base model
i bought an ac delco 10457702 part number
when I took it to the shop. they said the coil was messed up really bad. but i know the coil and the distributor are two different pieces?
since i bought the distributor complete. do i need to buy the coil also? or is it already part of the distributor?
and if someone knows where to buy it a link would be great thanks
Old Aug 30, 2010 | 07:01 AM
vetteoz's Avatar
vetteoz
Two seperate items
Just select a coil that has the same type connectors as yours
http://www.summitracing.com/search/P...I/?Ns=Rank|Asc
http://tpiparts.net/93_97_camaro_ignition_coil?b=1
Old Aug 30, 2010 | 07:52 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Here's a pic of your LT1 coil (and ignition control module (ICM) for visual reference. Location is the same, passenger side (left) of front engine cylinder head.
Old Aug 30, 2010 | 08:53 AM
Mikes1991's Avatar
Mikes1991
If they say the coil is bad perhaps itis not the opti. Try having just the coil replaced first if you havent done the opti yet
To new distributor
