service asr???
Old Aug 30, 2010 | 01:59 PM
spencelll's Avatar
spencelll
2nd Gear
Default service asr???
i got this lighting up on my 1993 c3. i triedto look it up in the haynes repair manual but i couldnt find it. any help would be appreciated.
Old Aug 30, 2010 | 02:56 PM
sailorsteve's Avatar
sailorsteve
Check for low brake fluid first, especially if you see the "brake" light too.
Beyond that, there is probably a code stored that you can retrieve with the FSM as a guide, or possibly someone has detailed it in a thread here, you could use the "search" function on the forum to look for it.
Old Aug 30, 2010 | 02:58 PM
toptechx6's Avatar
toptechx6
First try topping off the master cylinder as mentioned, the low fluid level switch will activate if it is just slightly low.
If that doesn't do the trick, see this link for some good ABS/ASR diagnostic information.
http://www.corvetteactioncenter.com/...abs/index.html
Last suggestion would be to ditch the Haynes, and buy the genuine Factory Service Manual, it will usually pay for itself on the first repair, you can find it here, or keep watching the C4 Parts for Sale forum and Ebay until you find a deal.
http://ncane.com/ljv0
To service asr???
